Electricity Bill with system not adding up
- tdornbusch
08 Nov 2018 11:24 #6494
by tdornbusch
Electricity Bill with system not adding up was created by tdornbusch
Hi!
When I get modeling results for my electric bill with system, it is higher than the sum of the demand charge with system (flat), energy charge with system, and fixed monthly charge with system. How can this be? I could see it being lower due to net metering credits, but am not sure what could cause it to be higher.
Second, what is the difference between demand charge with system (flat) and demand charge with system (TOU)?
Thanks for your help! I have attached a screenshot of my results if that helps.
13 Nov 2018 17:38 #6495
Replied by Paul Gilman on topic Electricity Bill with system not adding up
Does your rate structure include both flat and TOU demand charges? If so, SAM includes both in the bill calculation.
On the Electricity Rates input page, you'll see two tables for entering demand charge data. The "flat" charge is the total charge from the rates defined under "Demand Rates by Month with Optional Tiers." The "TOU" charges is from the "Demand Rates by Time-of-use Period and/or Tiers" rate table.
- Ayan Ahmed
24 Apr 2022 15:27 #10870
by Ayan Ahmed
Replied by Ayan Ahmed on topic Electricity Bill with system not adding up
Exactly, I am able to find the demand charges data in the table.
mepcobillonline.pk
mepcobillonline.pk
- Karl Woodson
16 Aug 2022 05:38 - 16 Aug 2022 07:58 #11351
by Karl Woodson
Replied by Karl Woodson on topic Electricity Bill with system not adding up
I was Also facing higher than the sum of the demand charge with system (flat) But Thanks to Paul My CalculationsĀ error was fixed
Regards
Karl
Regards
Karl
Last edit: 16 Aug 2022 07:58 by Paul Gilman.
