SAM, followed an OOP programming feature ?
- fayya
26 Sep 2018 23:37 #6459
by fayya
SAM, followed an OOP programming feature ? was created by fayya
Hi everyone,
I know that SAM was developped using the C++ lanquage, but I would like to know if the software was developped following an object oriented programmation approach or a procedural approach.
Thank you so much
Thank you so much
27 Sep 2018 12:39 #6460
Replied by Paul Gilman on topic SAM, followed an OOP programming feature ?
SAM is a very large program with lots of code, which you can see in the open source repositories hosted on GitHub.com:
https//github.com/nrel/sam
The code is organized into modules and uses object-oriented concepts like classes and inheritance, but also has some sections that are more procedural.
