Cooling tower water use results
- FrankNam
17 Aug 2018 04:25 #6410
by FrankNam
Cooling tower water use results was created by FrankNam
Good day SAM team
I am trying to wrap my head around the results relating to water use in SAM. The only result that can be viewed is "Hourly Data: Cycle cooling water mass flow rate - makeup". Please clarify whether this parameter is only the flow rate through the cooling tower, or in fact the WATER USE of the plant, I.E. cooling tower water use, as stated on page 71 in the technical document available at: www.nlr.gov/docs/fy11osti/51825.pdf . Since the cooling water circulation rate through the tower is not explicitly the water use, or consumption rate, it rather distorts any possible reporting on plant consumption. If I am committing any general ignorance, please feel free to correct me.
Many thanks for your time and continued hard work!
Frank
Frank
20 Aug 2018 14:17 #6411
Replied by Paul Gilman on topic Cooling tower water use results
Dear Frank,
Yes, the "Cycle cooling water mass flow rate - makeup" variable is equivalent to the water mass flow rate shown in Equation 3.25 of the Physical Trough Reference Manual. The equation is online 1402 of the source code:
github.com/NREL/ssc/blob/develop/shared/lib_powerblock.cpp
- Naresh Goud
18 Jul 2020 23:47 #8448
by Naresh Goud
Replied by Naresh Goud on topic Cooling tower water use results
As per the Cooling Water System Equipement, it is Flowrate through the Cooling Tower but not that water use in the Plant
