Incidence angle modifier
- Mavadivajjala
11 Jul 2018 03:54 #6336
by Mavadivajjala
Incidence angle modifier was created by Mavadivajjala
Hi Support People,
While calculating the Incidence angle modifier I'm used to having a matrix of values for longitudinal and transversal IAM for various incidence angle combinations for tubular collectors.
for eg
Dir. | 0° | 15° | 30° | 45° | 60° | 75° | 90° |
Trans. IAM | 1.00 | 1.01 | 1.03 | 1.05 | 1.04 | 1.02 | 0.00 |
Long. IAM | 1.00 | 1.00 | 0.98 | 0.96 | 0.90 | 0.71 | 0.00 |
Can you tell me how the SAM suggests single value of IAM while choosing the collectors for Solar hot water System?
Regards
Mavadi
for eg
Regards
Mavadi
11 Jul 2018 10:05 #6337
Replied by Paul Gilman on topic Incidence angle modifier
Dear Mavadi,
SAM's Solar Water Heating model uses the incidence angle modifier equations from Duffie and Beckman's Solar Engineering of Thermal Processes for flat collectors, which use a single incidence angle modifier coefficient. These equations are described in Section 6.17 of the Fourth Edition of the book. You can see how these equations are implemented in SAM in the following source code around Line 435:
github.com/NREL/ssc/blob/develop/ssc/cmod_swh.cpp
