Call SAM using Excel VBA
- xpeng37@wisc.edu
06 Jul 2018 07:40 #6328
by xpeng37@wisc.edu
Call SAM using Excel VBA was created by xpeng37@wisc.edu
Is it possible to call SAM directly from EXCEL using vba code?
I think it could since the code generator can generate vba code. I try that but it generated a bunch of csv files, I go through them and could not figure out where the vba code sits?
Could you point me to the code or provide me with an vba call SAM example?
Xinyue
Xinyue
06 Jul 2018 09:42 #6329
Replied by Paul Gilman on topic Call SAM using Excel VBA
Dera Xinyue,
Yes. You can use SAM's code generator to generate VBA code, and then use that in Excel.
When you use the code generator, you should see a bunch of CSV files that store inputs that are large arrays or tables along with a .bas file that contains the code. For example, if you run the code generator from a case named "untitled," you should see a file named untitled.bas along with the CSV files you mentioned, and copies of th ssc.dll and sscapi.h files
Also, to see other discussions about using VBA with SAM, see these search results:
sam.nlr.gov/search/site/vba
