Accuracy of PV and/or Wind modeling?
- TJC
20 Jun 2018 12:17 #6299
by TJC
Accuracy of PV and/or Wind modeling? was created by TJC
Hello Paul,
Can you give me an idea of the accuracy of the output of SAM?
Let me be more specific:
1. If I build a "PV power plant" at location "A".
2. I then do a SAM run of the precise same plant in location "B".
Taking ONLY the power generated, would the kWhrs/year be accurate within 1%, 2%, 5% or x?
I assume the variables are:
- The accuracy of the pyranometer used.
- The accuracy of the data notator whose records get loaded into the SAM weather file.
- The accuracy of the PV module insolation/power output curve.
- etc.
I understand that weather changes each year, but that is not my question.
I am trying to understand the case where if location "B" indicates 2% more power generated, is that site REALLY likely to demonstrate 2% better performance over time?
Tom
- etc.
Tom
25 Jun 2018 11:20 #6300
Replied by Paul Gilman on topic Accuracy of PV and/or Wind modeling?
Dear Tom,
The accuracy of SAM's results depend on the quality of your inputs. For a discussion of weather data for solar energy modeling, see this publication from NREL. You might try searching the document for the term "accuracy:"
www.nlr.gov/docs/fy15osti/63112.pdf
If you have access to different weather data for the two locations, I would recommend running simulations using the different weather data to see if the difference in output is consistent.
