Simulation error
- Ahmadabu
26 Apr 2018 10:32 #6211
by Ahmadabu
Simulation error was created by Ahmadabu
I tried importing a data file into SAM for simulation and I keep getting this error message. "missing temperature nan W/m2 at time [y:1999 m:1 d:1 h:0], exiting Simulation pvsamv1 failed." I used the software's solar resource file checker and it said there are no issues with the solar resource file, please what could be the problem?
26 Apr 2018 11:45 #6212
Replied by Paul Gilman on topic Simulation error
Dear Ahmadabu,
Could you attach a copy of your weather file to your original post above (Edit the post to attach a file)? Otherwise, please email it to me at SAM Support .
- Ahmadabu
28 Apr 2018 12:12 #6213
by Ahmadabu
Replied by Ahmadabu on topic Simulation error
I have attached the weather file as directed.
30 Apr 2018 10:02 #6214
Your weather file uses the column label "TEMP" for temperature, which SAM does not recognize. The accepted labels are listed in the "Weather File Formats" topic in SAM's help system.
For example, you can change the label to "TDRY" -- note that SAM ignores case, so you could also use "tdry" or "Tdry".
Also, the photovoltaic performance models require a column of wind speed data, so you will need to add that to your file.
30 Apr 2018 10:14 #6215
For example, you can change the label to "TDRY" -- note that SAM ignores case in the labels, so you could also use "tdry" or "Tdry".
