Isolated or independent PV-systems
- yunling.li
18 Apr 2018 17:28 #6185
by yunling.li
Isolated or independent PV-systems was created by yunling.li
Hello!
I'm doing a project about PV-residential/commercial taking Piura,Peru region as a reference and I'm analyzing how the project will change if enable battery; but I don't know how to set up that the battery only load from the system.
Also, I know the program simulate different projects that are conexion to the grid and when there are excess generation,these energy is injected to the grid. However, in Peru can not perform the same.
So how I can simulate a independet system without conexion to the grid; with battery storage that load with the excess generation and when the system cannot provision the necessary electric load, the battery cover the demand and no the grid .
Please If you have a video with an example about this. Let me know.
Thanks you.
Thanks you.
19 Apr 2018 09:04 #6186
Replied by Paul Gilman on topic Isolated or independent PV-systems
Please see this post for information, including a link to a webinar recording, about using SAM to model a battery-only system:
sam.nlr.gov/node/69715
SAM always assumes that the system is connected to the grid. However, you can design the PV and battery system to avoid consuming grid power.
- yunling.li
19 Apr 2018 11:19 #6187
by yunling.li
Replied by yunling.li on topic Isolated or independent PV-systems
Hi Paul, do you have any example or video where the design the PV and battery system to avoid consuming grid power?
Thanks you
Thanks you
19 Apr 2018 14:18 #6188
No, I do not have such an example. You would basically need to make the PV array and battery bank large enough that "Electricity from grid" is zero or very small over the entire year.
- yunling.li
20 Apr 2018 10:10 #6189
by yunling.li
So if the system is connected to the grid, how I can do that the excess generation don't be injected to the grid?
20 Apr 2018 18:01 #6190
You can ensure that the project does not receive payment for power injected to the grid by setting the sell rate on the Electricity Rates page to zero.
It is not possible to prevent power from being injected to the grid. "Electricity to grid" represents the excess power that needs to be managed by the system with dump loads, additional storage, or shifting existing loads.
