analysis of solar power plant
20 Mar 2018 10:00 #6142
Replied by Paul Gilman on topic analysis of solar power plant
There are several factors that might cause SAM's results to be different from measured data from a real system. For example, the weather data you use for SAM's simulation should represent the same conditions under which the real system operated. Also, you should make sure that the shading and loss assumptions in SAM are consistent with how the real system operates. And, you should be careful that the module, inverter, and system design parameters in SAM are the same as those for the real system.
You might find these photovoltaic system case study reports to be helpful:
sam.nlr.gov/case-studies
20 Mar 2018 10:05 #6143
When you change the module parameters to compare different cell types, you should be sure to take into account the nominal capacities of the different modules. There are factors of a module's design other than the cell type that affect its efficiency. For example the module cover might affect the module efficiency.
SAM reports the energy yield metric and module efficiencies in each simulation time step that might be useful for this kind of comparison.
- akshata
21 Mar 2018 00:01 #6144
by akshata
Replied by akshata on topic analysis of solar power plant
Photovoltaic system case study reports are very much helpfull for my studies. Thank you sir.
