High Pressure Water Properties into SAM
- Allan54
12 Mar 2018 19:58 #6134
by Allan54
High Pressure Water Properties into SAM was created by Allan54
I'm running the Process Heat Parabolic Trough simulation. I get a warning when entering water outlet temperatures above 300C which they can be if a very high pressure system is being simulated. Pressure can be up to 11MPa. Is the warning real? Is there a database I can input for higher pressures and temperatures. Any help is appreciated. Thanks (newbie to SAM)
13 Mar 2018 15:02 #6135
Replied by Paul Gilman on topic High Pressure Water Properties into SAM
Dear Allan,
In case you haven't seen it, the following video introducing the IPH trough model might be helpful:
sam.nlr.gov/node/74797
In general, when you change design parameters like the loop HTF temperatures, you may need to adjust other parameters accordingly. You can explore the outputs to see if the operating temperatures and pressures are what you expect, and then make adjustments to inputs.
If you need more help, please tell me what specific error you are seeing, and if possible attach your .sam file (edit your original post above) so I can better understand what you are describing.
