SAM code
- alsagria1
05 Mar 2018 08:14 #6086
by alsagria1
SAM code was created by alsagria1
Good morning.
I am modeling a CSP system, SAM tool is great. Is there anyway to generate the code?
I mean I want to see the code behind the SAM! it is based on TRNSYS (can I have TRNSYS file after I am done with SAM for further analysis?)
05 Mar 2018 17:19 #6087
Replied by Paul Gilman on topic SAM code
You can find SAM's C++ source code on GitHub here:
github.com/nrel/sam
The C++ files that contain the CSP model implementations are in this repository:
github.com/NREL/ssc/tree/develop/tcs
github.com/nrel/sam
- y.ennassiri
06 Mar 2018 18:20 #6088
by y.ennassiri
Replied by y.ennassiri on topic SAM code
Please i need help !!
I want to combine the source code of specifics SSC modules with an another code in ordre to build my own model (hydrogen electrolysis from PV/CSP system).
Please I need to know how might it done and if it is possible that someone explain the steps that i have to follow...
- Angus King
11 Mar 2018 09:10 #6089
by Angus King
Replied by Angus King on topic SAM code
Yassine
Not sure if this is possible but if the outputs from a SAM model, such as hourly generation, can be used as inputs to your hydrogen electrolysis "process" then using the generate code option of SAM is an option. You could extend the code produced by SAM to use the outputs as input to your part of the overall model.
Kind regards
Angus
Kind regards
Angus
