User-defined HTF - IPH Trough Model
- Marcos Diego Paes
31 Jan 2018 18:40 #6044
by Marcos Diego Paes
User-defined HTF - IPH Trough Model was created by Marcos Diego Paes
I'm having some issues with the HTF user-defined data table when simulating with the Process Heat Parabolic Trough model (SAM Version 2017.9.5, 64 bit, updated to revision 2).
When I run the simulation I get the following message:
exec fail(trough_physical_iph): The user defined field HTF table must contain at least 3 rows and exactly 7 columns. The current table contains 1 row(s) and 1 column(s)
Simulation trough_physical_process_heat failed.
Using the same user-defined data table in the CSP parabolic trough (physical) model it works normally, as well as when I run the simulation in the SAM Version 2017.1.17.
Is that a known problem or am I doing anything wrong?
Thank you for your attention.
Marcos Diego Paes
Marcos Diego Paes
01 Feb 2018 11:04 #6045
Replied by Paul Gilman on topic User-defined HTF - IPH Trough Model
Dear Marcos,
That appears to be a problem with the IPH Trough model. We are investigating that, and I will get back to you when I have more information.
