CSP
- alper
06 Jan 2018 11:15 #6007
by alper
CSP was created by alper
Hi
I am working on CSP physical
HTF user defined DOWTHERM A
But ? have error below
time 3600.00 { Physical Trough Solar Field 2 }:
The solution encountered an unresolvable NaN error in the heat loss calculations. Continuing calculations...
how can I fix ???
good night
how can I fix ???
good night
08 Jan 2018 15:47 #6008
Replied by Paul Gilman on topic CSP
If you are only seeing a few of those simulation errors, you can probably ignore them, because the will not have a large effect on the total annual output of the system, which is the value that is important for the cash flow calculations.
