negative energy
11 Dec 2017 11:22 #5930
Replied by Paul Gilman on topic negative energy
The Tamanrasset.epw weather file is not correctly formatted. There is a problem with the header. The Hassi Rmel.epw file looks ok. You can run the "Solar Resource File Checker" macro to help you find problems with your weather files. (Click the "Macros" button under "Simulate" to display a list of macros.)
There may be a problem with the custom HTF properties you provided. Can you double check the values in the table to make sure they are correct?
The field aperture area seems small for a 100 MW power cycle. You may want to set the Solar Multiple to 1 and allow SAM to size the field based on the power cycle rated capacity.
It appears that you are using an old version of SAM, SAM 2015.6.30. The latest version is SAM 2017.9.5. I would recommend using the latest version.
- sofiane
11 Dec 2017 12:04 #5931
by sofiane
Replied by sofiane on topic negative energy
OK
I simulated with Therminol VP-1, but i found same problem
Best regards
Best regards
11 Dec 2017 16:16 #5932
You may want to systematically change inputs one by one from their default values to find the problem. First, create a new case, change only the weather file and run a simulation. Then, change the field aperture area and run a simulation. Then change the loop configuration, etc. Otherwise, it can be difficult to isolate the input that is causing the problem.
- sofiane
17 Dec 2017 11:53 #5933
by sofiane
Ok,thanks
Best regards
Sofiane
Best regards
Sofiane
- sofiane
17 Dec 2017 11:55 #5934
by sofiane
This model is for stillwater
Best regards
Best regards
- amon10
28 Dec 2017 05:17 #5935
by amon10
Replied by amon10 on topic negative energy
Problem in overrun behavior in 3d scenario.
Until two days ago I was a user of the 2016 version for Sam's windows. I made the up grade for current version 2017 and realized that when entering with an active surface on a box or roof appear shading data even having meters of difference between the box, roof and the active surface. This behavior did not happen in the 2016 version. Has anyone ever encountered this behavior?
