Collector heat removal factor
- thilina fdo
30 Nov 2017 22:13 #5917
by thilina fdo
Collector heat removal factor was created by thilina fdo
NEED HELP!!!!
What is collector heat removal factor?
And does the SAM parabolic trough physical model has this factor?
01 Dec 2017 10:09 #5918
Replied by Paul Gilman on topic Collector heat removal factor
That term may refer to the collector heat losses. For SAM's physical trough model, the heat loss parameters are defined on the Receivers (HCEs) input page. SAM reports the heat losses calculated during the simulation as "Field thermal power receiver loss (MWt)" and "Field thermal power avg. receiver loss (W/m)" in the time series results, which you can find on the Data Tables tab, Time Series tab and other tabs on the Results page.
- thilina fdo
02 Dec 2017 00:21 #5919
by thilina fdo
Replied by thilina fdo on topic Collector heat removal factor
Thank you Paul. Cheers!!
