Load Preference battery
- EngineerStudent
26 Nov 2017 05:23 #5905
by EngineerStudent
Load Preference battery was created by EngineerStudent
Is it possible you can determine which load has priority on others?
For example: You have 1 battery 40% full and 2 loads, one important and one not (like in a hospital: life save equipment and lights) So when the battery can't provide both loads, can you choose which load has priority?
27 Nov 2017 11:43 #5906
Replied by Paul Gilman on topic Load Preference battery
SAM does not have a mechanism for separating the electric load into separate loads with different priorities.
You can use the manual dispatch option to control when the battery is charged and discharged.
