PTC and LFR
- nepalbinay
09 Nov 2017 06:22 #5856
by nepalbinay
PTC and LFR was created by nepalbinay
I am doing a performance analysis of physical model parabolic trough and linear fresnel reflector. When I ran the simulation, I found everything fine except the absence of "Plant Efficiency" in the result summary (other results like annual energy, gross to net conversion, capcity factor, and water usage were available). Do SAM automatically provide the value of plant efficiency or I need to calculate it seperately? I am a student and new user of SAM, so help me with this, please.
09 Nov 2017 12:49 #5857
Replied by Paul Gilman on topic PTC and LFR
Both of those models report the "Cycle efficiency (gross)" in the time series results. You can find that variable after running a simulation on the Results page Data tables, Time series, Profiles, Statistics and Heat Map tabs.
- nepalbinay
09 Nov 2017 21:28 #5858
by nepalbinay
Replied by nepalbinay on topic PTC and LFR
Thank you Paul
