SAM Broken with Windows 10 1709 Fall Creators Update
- LeeMerrill
23 Oct 2017 08:04 #5789
by LeeMerrill
SAM Broken with Windows 10 1709 Fall Creators Update was created by LeeMerrill
SAM does not work correctly with Windows 10 1709 update released last week.
Menu systems do not allow for saving, renaming, changing models, adding battery storage, etc. all menus I tested seem broken with the new version of Win 10. The keyboard shortcuts do work, so it appears to be a UI bug.
I have a small screen capture (mp4 format) if the dev team needs examples.
Thanks.
Thanks.
23 Oct 2017 09:45 #5790
Replied by Paul Gilman on topic SAM Broken with Windows 10 1709 Fall Creators Update
Dear Lee,
A screen capture would be helpful. Please either attach it to your original post by editing it (I just added .mp4 as an approved file attachment type), or email it to us at the address provided on the Contact page . Also, would you mind telling us what your display resolution and scaling setting is?
- Serge
23 Oct 2017 22:53 #5791
by Serge
Replied by Serge on topic SAM Broken with Windows 10 1709 Fall Creators Update
Same problem. Can't modify name, or user specification on modules, and inverter. Same windows update.
24 Oct 2017 10:48 #5792
Microsoft is releasing a major update to its Windows 10 operating system this month called "Fall Creators Update." It is causing problems for several applications, including a user interface problem in SAM that prevents menus and lists from working properly. We have a fix, and will release a SAM update as soon as we can.
30 Oct 2017 09:33 #5793
We release a SAM update today, SAM 2017.9.5 r2, that should fix this problem. Please let us know if you continue to have trouble with SAM on this version of Windows 10.
