Send data to Excel
- bruna
14 Sep 2017 07:38 #5714
by bruna
Send data to Excel was created by bruna
When I try to send the data to excel, it goes from a value that's suppose to be 1.0 to 100.000. Also, when I check the battery data and try to send those to excel, they come all wrong, it's suppose to be a value 1e^-16 and ir goes 1e^-11 or 1e^-12, it doesn't have a pattern.
14 Sep 2017 09:45 #5715
Replied by Paul Gilman on topic Send data to Excel
Can you describe more what you are doing, and if possible attach examples to your post above (click Edit to add attachments)? What steps did you follow to send the data to excel?
- bruna
18 Sep 2017 19:03 #5716
by bruna
Replied by bruna on topic Send data to Excel
I did a pv simulation, and I am going to calculate some statistics and some graphs about the energy from load to grid, with and without a battery installed in the system. So, when I click on "Send to Excel" the data from SAM to excel appears with errors from decimal to thousands. I'll add the attachments above! Thanks.
19 Sep 2017 16:04 #5717
Thank you for sending those files.
I think this might have something to do with Excel misinterpreting decimal points from SAM. You can see that in your screenshot: Values like 0.938691 are correctly transferred, while values like 1.0695 are not. Also, the very small numbers in scientific notation have commas in Excel instead of decimal points.
My Windows computer is configured for U.S. language settings, which includes using '.' for the decimal symbol and ',' for the digit grouping symbol. I changed those settings to the reverse, and got the same results as you.
As a temporary solution, you can try this: Close SAM, and then temporarily change your Windows number format settings to use '.' for decimal symbol and ',' for digit grouping. Then start SAM, and try sending the data to Excel. I found the number format settings in the Windows "Region" settings by clicking "Additional settings."
- bruna
19 Sep 2017 16:32 #5718
by bruna
This did work! I changed my Excel settings, so I could use '.' for decimals, now it`s working.
Thank you, very much!
Bruna.
Bruna.
