Solar Field Inital Temp.- Empirical Model
- fernando piris
25 Aug 2017 15:32 #5663
by fernando piris
Solar Field Inital Temp.- Empirical Model was created by fernando piris
How can I determine the Solar Initial Temp. in the Empirical Model of Parabolic Through? Or why the default value in SAM is 100 °C? I'm modeling a Solar Plant with Therminol VP-1 as HTF
31 Aug 2017 11:02 #5664
Replied by Paul Gilman on topic Solar Field Inital Temp.- Empirical Model
Dear Fernando,
The empirical trough model's solar field initial temperature is the temperature at midnight on January 1. The model uses previous hour temperatures to calculate current hour temperatures, so needs an input value for the very first hour of the simulation.
The default value is just a starting point, you can change the value to something else. For example, you could run a simulation to see what the calculated temperature is for January 2, and then set the initial temperature to a value closer to that one.
