Customize Micro Inverter Specifications?
- Pavesa
23 Aug 2017 13:18 #5660
by Pavesa
Customize Micro Inverter Specifications? was created by Pavesa
Hi
I'm using SAM to try and generate comparative annual production figures for a solar PV system. It will have LG 315 Watt modules and I'm wanting to evaluate the output with the M250 micro inverter (now out of production) and also with the AP Systems YC500i.
I'd like to be able to change some of the parameters for the micro inverters, eg/ Maximum AC Power on the "Inverter" page and I was wondering if there is any way to do this?
Thanks..
Thanks..
24 Aug 2017 10:23 #5661
Replied by Paul Gilman on topic Customize Micro Inverter Specifications?
Dear Pavesa,
Thank you for the message. To model inverters not in the library, or to use your own parameters for an inverter, use the "Inverter Datasheet" option on the Inverters input page. You can find that option in the blue drop-down list at the top of the Inverter input page.
- Pavesa
24 Aug 2017 11:17 #5662
by Pavesa
Replied by Pavesa on topic Customize Micro Inverter Specifications?
Hi Paul
thanks, I'll take a look!
