hourly sub-array output
- vas013
30 Jul 2017 00:39 #5592
by vas013
hourly sub-array output was created by vas013
Is it possible to get the hourly sub-array DC output? I am modelling a system with 3 sub-arrays; facing east, north (southern hemisphere) and west. I would like to optimise the sizing for each sub-array if possible, but can't find the hourly data. There is hourly current and voltage, so presumably it is calculated?
31 Jul 2017 10:50 #5593
Replied by Paul Gilman on topic hourly sub-array output
SAM's photovoltaic model does not report the DC power output of individual subarrays. It only reports the total array DC power output.
If you want to see the output of each individual subarray, you might try modeling each one as a separate case in SAM.
- vas013
01 Aug 2017 22:45 #5594
by vas013
Replied by vas013 on topic hourly sub-array output
Thanks Paul. That's what I did originally, which works fine. The limitation is that you can't then simulate all the parametrics across the cases. But I can do it manually I guess!
- Tom Durston
09 Nov 2017 07:31 #5595
by Tom Durston
Replied by Tom Durston on topic hourly sub-array output
I need the maximum hourly current for a system where there could be power clipping due to inverter maximum usable input current. The PV hourly data includes Array DC Power and Subarray Operating Voltage. Is it correct to calculate hourly current = Array DC Power/Subarray Operating Voltage for each hour, assuming that there is only 1 subarray?
09 Nov 2017 12:47 #5596
Dear Tom,
You might want to use the "Inverter DC input voltage (V)" variable for that purpose. For a system with one subarray, its value should be the same as "Subarray 1 operating voltage (V)."
- Tom Durston
11 Nov 2017 18:18 #5597
by Tom Durston
Thanks very much.
