Part Load Efficiency - SAM
- marinacmasca
09 Jun 2017 12:24 #5506
by marinacmasca
Part Load Efficiency - SAM was created by marinacmasca
When I choose on SAM the Part Load Efficiency Model for Inverters and I will type the values given by the manufacturer, which voltage is being considered by SAM? Because the Datasheet will give me the efficiencies according to the load in 3 options:
- Minimum MPP voltage
- Rated input voltage
- Maximum MPP voltage
Which one is more suitable?
12 Jun 2017 11:26 #5507
Replied by Paul Gilman on topic Part Load Efficiency - SAM
You can enter those voltages in the "Operating Ranges" box, where they are listed as:
Minimum MPPT DC Voltage (Vdc)
Nominal DC voltage (Vdc)
Maximum MPPT DC voltage (Vdc)
SAM uses the MPPT voltage range to calculate inverter clipping losses.
