Battery maximum State-of-Charge
- Giovani Dávi
02 Jun 2017 04:11 #5487
by Giovani Dávi
Battery maximum State-of-Charge was created by Giovani Dávi
I am analyzing a detailed PV and electrochemical storage, commercial case study. Some details about the model are: battery system of 5 MWh capacity, VRLA AGM battery technology, battery bank voltage = 96 V, AC connected, battey state-of-charge (SoCmin = 40%, SoCmax = 100%). My question is: the battery state-of-charge never reaches the maximum SoC 100% over the year. I suppose could be something with respect the battery model. Somebody could me help on this?
I send attached a detailed SoC output.
Giovani Dávi
Giovani Dávi
02 Jun 2017 12:13 #5488
Replied by Paul Gilman on topic Battery maximum State-of-Charge
Dear Giovani,
Please check the "Maximum state of charge" input on the Battery Storage input page. It is set to 95% by default for the default Lithium-ion battery. You can change it to 100% if you want to allow the battery to reach 100% state of charge.
- Giovani Dávi
05 Jun 2017 04:48 #5489
by Giovani Dávi
Replied by Giovani Dávi on topic Battery maximum State-of-Charge
Thank you for your reply Paul.
I am actually using SoCmaximum = 100% (SoCminimum = 40%), simulating with VLRA AGM battery technology.
Giovani
Giovani
06 Jun 2017 16:46 #5490
Dear Giovani,
Would you mind adding your SAM file as an attachment to your original post (edit the post to add the attachment), or emailing it to me?
- Giovani Dávi
07 Jun 2017 03:03 #5491
by Giovani Dávi
Thank you Paul.
I sent you an email with the SAM file.
Giovani
Giovani
12 Jun 2017 13:09 #5492
Dear Giovani,
Thank you for sending the file, and sorry for my slow response.
There are a few things that are preventing the battery from being fully charged:
- The system size is small compared to the load: The annual output of the system is 1.3 million kWh/yr, and the total annual load is 4.8 million kWh/yr. That means there is not a lot of excess PV energy available to charge the battery.
- The system prioritizes meeting the load before charging the battery ("PV meets load before charging battery").
- The grid is not allowed to charge the battery, so all charging must be done by the PV system.
