Longitude e latitude não especificado
- maiconbastos
26 Apr 2017 12:54 #5379
by maiconbastos
Longitude e latitude não especificado was created by maiconbastos
I created a typical meteorological year to simulate a system of energy generation by solar concentration, but when I put to run the file is giving an error of Longitude and Latitude unspecified, I tried everything and I can not solve this error, I tried to even create The file in the 2013 version.
I am using Excel to build the file.
I would have some other software for editing the files.
Thank you in advance.
26 Apr 2017 15:07 #5380
Replied by Paul Gilman on topic Longitude e latitude não especificado
Would you mind attaching a copy of your file to your original post (log on to the website, and click Edit above to add the attachment). You could also email it to me.
- jforbess
11 Jul 2017 17:15 #5381
by jforbess
Replied by jforbess on topic Longitude e latitude não especificado
I experienced the same problem. I will email you the file, since it's a private dataset.
- jforbess
11 Jul 2017 17:22 #5382
by jforbess
Actually, I checked the header again, and discovered that I should edit that line in a text editor instead of excel to make sure it was correctly formed. It now loads, once I made sure to include the correct number of commas.
14 Jul 2017 17:31 #5383
In general, when working with your own weather files, I recommend reviewing the file with a good text editor to find any formatting issues that may not be visible in a spreasdheet program like Excel.
For example, if you are working on a Mac, be sure that your line endings are Unix (LF) or Windows (CRLF) rather than Mac (CR). Most text editors have a way to show and change line endings.
