Inverter datasheet challenge
- Achilles11
21 Apr 2017 14:43 #5370
by Achilles11
Inverter datasheet challenge was created by Achilles11
I need to input inverter specs in SAM's inverter datasheet as the inverter I'm working with isn't in the CEC database, however, I'm having trouble deciphering the product data sheet. The value headings and units in the attached datasheet don't exactly correspond to the SAM's data inputs, I'm wondering if someone can help identify the rights values for SAM:
Operating ranges
Nominal AC Voltage (Vac)
Max DC Voltage (Vdc)
Max CD Current (Adc)
Min MPPT DC Voltage (Vdc)
Nominal DC Voltage (Vdc)
Max MPPT DC voltage (Vdc)
Thanks!
Operating ranges
Thanks!
24 Apr 2017 09:59 - 19 Jan 2022 10:52 #5371
Replied by Paul Gilman on topic Inverter datasheet challenge
Unfortunately, there are no standard requirements for these parameters, so you will find different names and definitions on different manufacturer's data sheets. The descriptions of the inputs SAM's Help system (see the topic for the Inverter input page) should help some. You can also compare data in SAM's library for the "Inverter CEC Database" option to the data sheet values for an inverter made by the same manufacturer.
For the GE inverter data sheet you provided:
Nominal AC voltage: 550
Maximum DC voltage: 1500
Maximum DC current: 1200
Minimum MPPT DC voltage: 890 (use the 50 degree value if the system will be in a hot environment)
Nominal DC voltage: 1075 (average of min and max MPPT, see note below)
Maximum MPPT DC voltage: 1300
Please see the following post for more on the nominal DC voltage:
sam.nlr.gov/forum/forum-general/1617
Last edit: 19 Jan 2022 10:52 by Paul Gilman.
- Achilles11
25 Apr 2017 11:11 #5372
by Achilles11
Replied by Achilles11 on topic Inverter datasheet challenge
Thanks Paul!
- Leandro de Oliveira
14 Jan 2022 06:12 #10509
by Leandro de Oliveira
Replied by Leandro de Oliveira on topic Inverter datasheet challenge
this link is broken
19 Jan 2022 10:51 #10521
Hi Leandro,
Thank you for pointing that out. Let's try this one:
I will change it in the original message above.
