Microinverter
- saman1368
12 Apr 2017 10:01 #5345
by saman1368
Microinverter was created by saman1368
Hi
I am modeling simple residential building with a PV system, I would like to compare the result of using micro-inverter and string inverter under the same shading condition. For string inverter, I've used 3D shading calculator (12 module per string, 1 string parallel, and 1 inverter) however for microinverter 1 module per string,12 string in parallel and 12 inverters, I would like to know is there anyway that I can use 3D shade calculator to calculate the shading for my system, if yes how,will it take into account the presence of micro-inverter or not.
12 Apr 2017 15:19 #5346
Replied by Paul Gilman on topic Microinverter
In short, yes. However, SAM's 3D shade calculator only works with up to 8 strings per subarray. To illustrate this, I added a third attachment to your original post. It is a SAM file with several cases described below:
Original
This is the original case from your file.
Microinverters
In this case, I modified your original case as follows:
String Inverter
Microinverter - One Module
This example uses a single module with one string inverter and partial shading enabled to show that SAM calculates partial shading for a single module in addition to doing so for a subarray of several modules.
Microinverter - One Module No Partial Shading
In this case, I disabled partial shading in the Shade window to compare with the previous case. When partial shading is disabled, SAM models external shading as a reduction in POA irradiance, and does not account for the effect of diodes on the module's DC output.
Please see the notes I wrote in the case (you'll see yellow post-it note icons in the navigation menu indicating where the notes are) for additional details.
Original
Microinverters
- Change the inverter to one with a capacity of 250 Wac so I could compare it to a system with a 2000 Wac string inverter
- Change the system design to a system with 1 module per string, 8 strings in parallel, and 8 inverters because SAM's 3D shade model cannot calculate shade losses for a system with more than 8 strings.
- In the 3D shade scene, replace the single active surface with 8 active surfaces, each representing a single module wired as a separate string (Subarray 1 consists of 8 strings of one module each).
- In the shade window, enable partial shading and set the number of strings to 8.
- On the Losses page, set the module mismatch loss to 0, assuming that the microinverter system would not experience those losses
String Inverter
- Use an inverter rated at 2000 Wac with a maximum MPPT voltage rating above the subarray open circuit voltage rating (appropriate for initial sizing)
- On the System Design page, set modules per string to 8, strings in parallel to 1, and number of inverters to 1. This makes the system design capacities comparable to the microinverters case.
- In the 3D shade scene, a single active surface represents the entire array.
- In the shade window, enable partial shading and set the number of strings to 1.
- saman1368
13 Apr 2017 12:57 #5347
by saman1368
Replied by saman1368 on topic Microinverter
Thanks a lot Paul
How can i download your attachment , i cant find it
- saman1368
13 Apr 2017 13:47 #5348
by saman1368
Thanks for clarification but i cant find the attachment
13 Apr 2017 18:53 #5349
Sorry -- it should now be attached to your original post above.
- saman1368
14 Apr 2017 11:28 #5350
by saman1368
Thank you so much Paul , It helped a lot
