Change variables analyzed when running P50/P90
- alemeleg
28 Mar 2017 10:11 #5295
by alemeleg
Change variables analyzed when running P50/P90 was created by alemeleg
Hi!
I am trying to modify the list of metrics that are calculated when running the P50/P90 simulation.
I´ve seen in HELP that this may be done under "Configure Simulations", but I´ve not been able to find this option in the latest SAM version.
How can I select different variable to appear when running the P50/P90 simulation?
I am attaching the default metrics the system is currently calculating.
29 Mar 2017 10:39 #5296
Replied by Paul Gilman on topic Change variables analyzed when running P50/P90
It is not possible to change the P50/P90 metrics for now. What metrics would you like to add?
