Problems with using custom weather data
- ssgouridis
26 Mar 2017 01:31 #5284
by ssgouridis
Problems with using custom weather data was created by ssgouridis
I would like to use SAM with custom weather data.
To do so, I have first copied a sample CSV file from the library.
When I use the copied file unedited, the simulation proceeds normally.
When I open the file with Excel and save it as a CSV even though I have not done any other change (i.e. the data are exactly the same) the simulation fails. I also tried another software - Open Tables but with the same results.
The error issued reads:
exec fail(Physical Trough): latitude and longitude required but not specified
Simulation tcstrough_physical failed.
SSC requires input ‘gen’, but was not found in the SAM UI or from previous simulations
Simulation singleowner failed.
This must be related to some other changes that happen to the file when the editing software saves it.
Is there a proper protocol for editing the CSV weather files without creating problems in the simulation?
Sgouris
Sgouris
- Angus King
27 Mar 2017 07:21 #5285
by Angus King
Replied by Angus King on topic Problems with using custom weather data
Sgouris
I may be completely on the wrong tack but perhaps when you're saving the file it isn't using a comma as the column delimiter. It might be worth doing a simple check.
Angus
Angus
27 Mar 2017 16:48 #5286
Replied by Paul Gilman on topic Problems with using custom weather data
Sgouris,
Please see this post about line endings in weather files. That may be causing the problem:
sam.nlr.gov/node/69915
