Any update on when multiple MPPT inverters will be supported?
- Marvin Hamon
16 Mar 2017 19:11 #5247
by Marvin Hamon
Any update on when multiple MPPT inverters will be supported? was created by Marvin Hamon
Multi-MPPT inverters have been on the market for a long time now, other software supports them, when can we expect SAM to support them?
24 Mar 2017 14:15 #5248
Replied by Paul Gilman on topic Any update on when multiple MPPT inverters will be supported?
We are planning changes to the user interface and underlying code to support inverters with multiple MPPT inputs, and hope to release that feature as a part of SAM within the next 18 months.
In the meantime, it would be helpful to us if you could provide us with a description of the type of system you would like to model. For example, why are you using different MPPTs? Is it support an array with different string lengths, one with modules oriented in different directions, with different types of modules, or for a different reason? How many different MPPTs would you like SAM to support?
- geofftoml
18 May 2017 19:59 #5249
by geofftoml
Replied by geofftoml on topic Any update on when multiple MPPT inverters will be supported?
It's usually having strings of different lengths on the same inverter. Maybe I only need an odd number of modules, so 12 on one string and 11 on another. Or different azimuths, 8 modules on a string facing south and 10 on a string facing west.
19 May 2017 13:08 #5250
Thank you for that additional feedback.
04 Feb 2019 09:20 #5251
As of Version 2018.11.11, SAM can model inverters with up to four MPPT inputs, and each subarray has its own "modules per string" input so the array can have up to four different string lengths.
See the release notes for a full list of new features.
