Excluding the auxilary heater
- m.nabil
10 Mar 2017 03:19 #5225
by m.nabil
Excluding the auxilary heater was created by m.nabil
Hello!
I am trying to simulate a parabolic trough power plant without an auxiliary heater. My question is: which input parameter do I have to change in order to exclude the auxiliary heater?
I have also noticed in the "Thermal Storage" tab that for both cold and hot tanks there is a a heater set point. Is it possible to eliminate the heater from the simulation?
I am using Therminol 66 as a HTF and TES medium with a field inlet temperature of 290°C and a field outlet temperature of 390°C.
Thanks!
Nabil
Thanks!
Nabil
10 Mar 2017 14:36 #5226
Replied by Paul Gilman on topic Excluding the auxilary heater
Dear Nabil,
I assume that by auxiliary heater, you mean "fossil backup," or supplementary heat from an auxiliary gas system. As long as the "fossil fill fraction" under "Dispatch Control" on the Thermal Storage page is zero for all periods, the model will not fossil backup.
The tank heater inputs are for freeze protection to prevent the HTF in the storage tanks from solidifying at night. SAM assumes that the tank heaters are electric. That is intended for molten salt as the storage medium. If you use an oil, the fluid temperature is not likely to reach the oil's freeze point. You can check the results to see if any power is consumed for TES freeze protection: The HTF temperatures are listed as "TES HTF temperature..." and the freeze protection power is listed as "Parasitic thermal field freeze protection."
- m.nabil
13 Mar 2017 04:12 #5227
by m.nabil
Replied by m.nabil on topic Excluding the auxilary heater
Your assumption is right, i meant the fossil backup.
Thank you Paul, that is very helpful.
Nabil
Nabil
