Hitec HTF Material Properties
- pietrop
29 Apr 2012 12:02 #523
by pietrop
Hitec HTF Material Properties was created by pietrop
I am using another software to simulate my whole process using impoting SAM's output and I need Hitec's HTF Material Properties Table that is saved in SAM.
Is there a way that I can access the HTF Properties library that SAM uses?
Specifically in order to define the fluid in the order software I need a table with these following properties as a function of the imposed Temperature:
Temperature, Density, Specific Heat, Thermal Conductivity, Dynamic Viscosity and Vapor Pressure
Could you please help me obtain this data?
Thank you.
Pietro Pecorari
Thank you.
Pietro Pecorari
- Unknown User
30 Apr 2012 02:39 #524
by Unknown User
Replied by Unknown User on topic Hitec HTF Material Properties
Hello Pietro,
the HTF properties have been posted here:
sam.nlr.gov/content/heat-transfer-fluid-properties
Regards
Timo
Regards
Timo
- pietrop
30 Apr 2012 19:32 #525
by pietrop
Replied by pietrop on topic Hitec HTF Material Properties
Thank you very much for your help Timo.
Best Regards,
Pietro Pecorari
Best Regards,
Pietro Pecorari
- pietrop
22 May 2012 08:16 #526
by pietrop
Dear Timo,
Thank you very much for the valuable data!
Most of the properties I need were in that file. The only data left is vapor pressure in the corresponding 21 points.
I know that Hitec HTS has a vapor pressure as low as 50 psig at 288°F(it's freezing point) it should increase with temperature at a real slow rate but I would like to quantify this rate in way that the inserted data is plausible.
Do you have this information or know anyone I can talk to at Coastal Chemical LLC that could give me this information?
Pietro Pecorari
Pietro Pecorari
