Simulation fails with 15-minute time steps
- oavaldezi
21 Feb 2017 15:54 #5173
by oavaldezi
Simulation fails with 15-minute time steps was created by oavaldezi
I'm using the Commercial Distributed Photovoltaic (PVWatts) model for a simulation, using 15-minute time intervals for the energy load data.
I input 35,040 values for the time intervals, and when I click the "Simulate" button, I get the following notice:
exec fail(utilityrate5): number of load records (35040) must be equal to number of gen records (8760) or 8760 for each year
Simulation utilityrate5 failed.
SSC requires input 'annual_energy_value', but was not found in the SAM UI or from previous simulations
Simulation cashloan failed.
No results are generated.
- stumpyd123
22 Feb 2017 04:28 #5174
by stumpyd123
Replied by stumpyd123 on topic Simulation fails with 15-minute time steps
Hello oavaldezi,
In order to run sub hourly simulations, the load data and the weather resource data must match time steps. So, you either have to find a 15 minute weather file, or consolidate your load file into hourly results.
If you need help consolidating your load file into an hourly file, I might be able to help for a fee.
David
David
- oavaldezi
22 Feb 2017 13:58 #5175
by oavaldezi
Replied by oavaldezi on topic Simulation fails with 15-minute time steps
Thank you, David. I need to keep the load data in fifteen-minute steps because of demand charge regulations.
I've pulled the relevant weather resource data, and I plan to interpolate for fifteen-minute intervals. My new question is: How do I represent the fifteen-minute intervals in the "Hour" column?
- oavaldezi
22 Feb 2017 14:11 #5176
by oavaldezi
I found a script
here
that will "Convert an hourly weather file in SAM CSV format from hourly to 15-minute data by replicating the data in each hour for each of the four 15-minute time steps in the hour."
I'll give it a try.
I'll give it a try.
22 Feb 2017 16:05 #5177
Replied by Paul Gilman on topic Simulation fails with 15-minute time steps
That script should work. You can modify it to use whatever interpolation method works best for you.
- stumpyd123
22 Feb 2017 23:16 #5178
by stumpyd123
I didn't even realize there was a script already made for it. Good to know. I was just going to use Pandas' resampling function in Python.
