Read srw correctly
- ivonnepena
21 Feb 2017 06:54 #5168
by ivonnepena
Read srw correctly was created by ivonnepena
I am trying to read a srw wind weather file in SAM store in my laptop. I am using OX. These are the steps I followed:
1. Copied the AR flatlands srw SAM stored file to check the format. Copied it in my desktop.
2. Followed the format and create a sample file called example.srw (that I am sending you). Saved it as .csv. Then, changed the extension in the name as .srw.
3. Create a wind project and use the wind resource of the AR flatlands srw copied in my desktop (I wanted to check it would run as if I would be using the file from the original location). Got the following error: failed to read local weather file: /Users/Ivonne/Desktop/AR Northwestern-Flat Lands2.srw error reading data column type specifier in col 1 of 128: '47' len: 2
Simulation windpower failed.
4. Did the same with example.srw. The hub height was read because I did not get the hub error specification, but I got the following error: exec fail(windpower): error reading wind resource file at 36:
Can you please point me how to solve this? I don't understand why the AR file is not being read (I did not change it, just put a copy of it in my desktop and change the name). And why mine (example) is not being read either.
Thanks much!
Thanks much!
21 Feb 2017 10:58 #5169
Replied by Paul Gilman on topic Read srw correctly
The problem with your file appears to be due to the line endings. Please see this post for more details. It is about solar resource files, but also applies to files in the SRW format for wind resource data:
sam.nlr.gov/node/69915
- H.Akhbari
12 Mar 2017 09:24 #5170
by H.Akhbari
Replied by H.Akhbari on topic Read srw correctly
The problem of software is all weather data not exist?
I need Iran weather data to important project.
Guide me, please!
Hossein
Guide me, please!
Hossein
- Angus King
13 Mar 2017 00:16 #5171
by Angus King
Replied by Angus King on topic Read srw correctly
Hossein
Please refer to sam.nlr.gov/node/71040 or contact me at siren@sen.asn.au regarding obtaining weather data for places such as Iran. We have a tool that will create SAM weather files using NASA MERRA2 data.
Kind regards
Angus
Kind regards
Angus
- H.Akhbari
13 Mar 2017 14:59 #5172
by H.Akhbari
dear Angus
Thank you so much,
I saw the web address and searched Iran so as founded, but West South of the Terhan and i want East North.
Then i will send E-mail to your address.
Kind regards
Thank you so much,
Kind regards
