Power tower molten salt
- Mwende
08 Feb 2017 02:37 #5137
by Mwende
Power tower molten salt was created by Mwende
A few questions on the power tower;
1. What exactly is the heliostat field multiple?
2.According to SAM help, the fossil dispatch mode/setting of fossil fill fraction should be in the power cycle page but can't seem to find any such option
3.Is the receiver set to external by default,looks like there aren't input parameters for cavity type
4.Is there any reference or indicative value of fossil back up cost ($/kWe) assuming you're using natural gas?
5.For the tower fixed cost,any indication on how this would vary with height?
NB:I'm using 2017 SAM.
Mwende.
Mwende.
08 Feb 2017 12:20 #5138
Replied by Paul Gilman on topic Power tower molten salt
Dear Mwende,
1. The solar multiple (under "Heliostat Field" on the System Design page) determines the receiver's nominal thermal power. It is the ratio of the receiver thermal power to the cycle thermal power. For a system with no storage, the solar multiple should be close to or equal to one. The heliostat field multiple input is not used by the molten salt power tower model, so you can ignore it. We will remove it in the next update to SAM 2017.1.17.
2. Can you tell me specifically where in Help you saw mention of the fossil dispatch mode? The molten salt power tower model does not include an option for fossil backup. The fossil backup system costs are included on the System Costs page because the System Costs input page is designed to work with both the molten salt power tower model and the direct steam power tower model. The latter includes options for modeling fossil backup.
3. It is not possible to model a power tower system with a cavity receiver in SAM 2017.1.17. Please see this post for more details: sam.nlr.gov/node/70062
4. In general, you can find information about costs on the System Costs page , but the documentation there of power tower costs does not include fossil backup costs.
5. Again, for information about system costs and SAM, please see the documents listed on the System Costs page .
- Mwende
09 Feb 2017 03:02 #5139
by Mwende
Replied by Mwende on topic Power tower molten salt
Hello Paul,
Thanks for your response.
In regard to the fossil dispatch mode for MS power tower, under Help, if you open CSP then power tower molten salt,on the power cycle page there's a section on 'Fossil dispatch mode'. Perhaps this part should be excluded since it doesn't apply like you said, to avoid confusion.
www.nlr.gov/analysis/sam/help/html-php/index.html?power_tower_molten_salt.html
Mwende.
Mwende.
09 Feb 2017 13:57 #5140
Dear Mwende,
That version of the Help system is for a 2012 version of SAM. The Help system in current version of SAM explains that fossil backup, along with the supercritical carbon dioxide power cycle and thermocline storage were removed from the power tower model after SAM 2015.6.30 because of the new dispatch and optimization models that do not support those features.
You can find the current version of Help in the SAM software, or you can download a (very large) PDF version from the Download page:
sam.nlr.gov/download
- Mwende
10 Feb 2017 03:55 #5141
by Mwende
Thanks for the clarification.
Mwende.
Mwende.
