Shading effects on PV - How do I get reverse diode voltage
- Dimitrij
26 Jan 2017 09:04 #5108
by Dimitrij
Shading effects on PV - How do I get reverse diode voltage was created by Dimitrij
Hello everybody,
I use some approaches from SAM to build my own model for bifacial power plants. In "SAM Photovoltaic Model Technical Reference" the approach of Chris Deline "A simplified model of uniform shading in large photovoltaic arrays", 2013 is used for calculating shading effects on a PV module. For this the value of "reverse voltage of the (bypass) diode" of the PV module is needed.
Now my question is: where do I get this value from? Some datasheets I checked don't provide this information. I also couldn't find where this value is entered in SAM.
Thank you very much for your support.
26 Jan 2017 16:42 #5109
Replied by Paul Gilman on topic Shading effects on PV - How do I get reverse diode voltage
Dear Dimitrij,
In the Deline article, they assume Vd = 0.5, and reference a paper by Bishop (1988) for the reverse-bias cell behavior.
For the non-linear self-shading option, SAM assumes that each module has 3 bypass diodes. The diode voltages are not inputs to the model.
- Dimitrij
27 Jan 2017 04:19 #5110
by Dimitrij
Replied by Dimitrij on topic Shading effects on PV - How do I get reverse diode voltage
thank you very much for your quick reply!
Unfortunately I am a mechanical engineer, not an electrical one, so I have only basic knowledge about diodes.
Did I understand you correctly that Vd=0.5 V is used in SAM for the bypass diode as a constant value which does not depend on the choosen module type?
I found a datasheet from the bypass diode "SM 74611" from Texas Instruments, which is used in PV modules. There they indicate the maximum reverse voltage as 30V, which is a completely different magnitude (attached file, page 1).
Kind regards
Dimitrij
Kind regards
Dimitrij
27 Jan 2017 15:40 #5111
Dear Dimitrij,
I think there is a difference between bypass and blocking diodes in the array circuit between modules, and the bypass diodes in the module circuit between individual solar cells in the module.
