Flowsheet for the CSP linear Fresnel Molten Salt model used by SAM with labeling the streams using the hourly data variables
- hys05
06 Dec 2016 00:47 #4977
by hys05
Flowsheet for the CSP linear Fresnel Molten Salt model used by SAM with labeling the streams using the hourly data variables was created by hys05
Dear SAM support team
I'm little bit confused about the Linear Fresnel molten salt model on SAM, I can't match the results hourly data with the flowsheet streams that I'm using(I attached the flowsheet that I'm using), I think that my flowsheet is very simple and wrong, so can you please provide me a detailed process flowsheet of the Linear Fresnel molten salt model on SAM with labeling the flowsheet with the hourly result variables(ex. Cycle HTF temperature in(hot)(C),Cycle HTF temperature out(cold)(C),TES HTF temperature HX field side hot(C)...etc) to have a complete understanding of the process.
I really appreciate your help, thank you very much.
Best Regards
Hamza
Best Regards
Hamza
- hys05
06 Dec 2016 00:48 #4978
by hys05
Replied by hys05 on topic Flowsheet for the CSP linear Fresnel Molten Salt model used by SAM with labeling the streams using the hourly data variables
Please I need help with this.
06 Dec 2016 10:32 #4979
Replied by Paul Gilman on topic Flowsheet for the CSP linear Fresnel Molten Salt model used by SAM with labeling the streams using the hourly data variables
Dear Hamza,
For diagrams of system configurations for both the molten salt and direct steam linear Fresnel models in SAM, please see the documents listed under "Linear Fresnel" on the Performance Model Documentation page:
sam.nlr.gov/performance
For descriptions of the model inputs, please see SAM's Help sytem.
- hys05
06 Dec 2016 12:05 #4980
by hys05
Dear Mr.Paul
Thank you very much for your response, but unfortunately the documents that you refereed me to are not so much useful to me since they are most concentrated on the solar field variables. What I'm actually looking for is to understand the whole linear Fresnel molten salt modeled in SAM, as a whole flow sheet(ex. how the fluids are flowing, streams connections...etc) it can be great if you can provide me with a process flowsheet block diagram of the linear Fresnel molten salt process that is used in SAM so I can understand the process as whole(ex. a block diagram with the stream connections and labels).So can you please provide me with such figure that shows all the blocks and there stream connections.
Best Regards
Hamza
Best Regards
Hamza
