Battery Storage on AC vs. DC bus
- tmartin
27 Oct 2016 09:57 #4870
by tmartin
Battery Storage on AC vs. DC bus was created by tmartin
Hi everyone,
This may be obvious to some, but why is the battery storage model on the AC bus only? In practice is this how systems are designed? It would seem to me that placing the battery on the DC bus would negate the additional DC-AC, AC-DC, and then back DC-AC efficiency losses created by placing the battery on the AC bus as opposed to the DC bus.
If in practice the battery is on the DC bus would that be a feature that could be added back to SAM? I read elsewhere that SAM used to have it.
Tane
Tane
28 Oct 2016 15:12 #4871
Replied by Paul Gilman on topic Battery Storage on AC vs. DC bus
Hi Tane,
We plan to add a DC-connected battery option in the next version of SAM tentatively scheduled for release in January 2017. For now, you can effectively model a DC-connected battery by using the AC to DC conversion efficiency to represent charge controller losses (with no rectification losses), and using the DC to AC conversion efficiency to represent losses associated with converting battery DC power to AC.
For this first iteration of the battery model, we chose to model batteries on the AC bus so that it could work with the output of SAM's PV model. To accurately model batteries on the DC bus, we need to make some modifications to how the PV models the DC bus voltage.
- tmartin
31 Oct 2016 00:08 #4872
by tmartin
Replied by tmartin on topic Battery Storage on AC vs. DC bus
Thanks Paul,
Thanks for the tips on how to model.
So does this mean that the reasoning is module-related? Just curious if it was related to practical residential storage application (with which I don't currently have much experience) limitations or standards.
Tane
Tane
31 Oct 2016 15:39 #4873
Hi Tane,
Our decision to model the battery as AC-connected had more to do with modeling limitations than with current common practice in the storage market.
