PV model with only GHI data?
- mfripp
08 Jun 2016 16:42 #4529
by mfripp
PV model with only GHI data? was created by mfripp
I would like to model performance of a single-axis tracking PV system, but I only have GHI data available, with no breakdown between beam and diffuse components. In the past I have estimated beam and diffuse components by fitting this to a clear sky model, and then used those beam and diffuse components for photovoltaic calculations. However I would rather not have to do that. Is SAM able to work with only GHI data and then estimate the beam and diffuse components internally for PV analysis?
- Angus King
09 Jun 2016 02:27 #4530
by Angus King
Replied by Angus King on topic PV model with only GHI data?
Matthias
Looking at sam.nlr.gov/node/70675 I think you need a second variable.
You might look at sam.nlr.gov/sites/sam.nlr.gov/files/content/documents/xls/DNI-GHI_to_DHI_Calculator.xlsx and rredc.nlr.gov/solar/models/DISC/ to calculate the other(s)
Angus
Angus
