Slight change to output from Data - Save
- Angus King
01 Jun 2016 20:55 #4478
by Angus King
Slight change to output from Data - Save was created by Angus King
In SAM 2015.6.30 when saving Hourly Data the Data - Copy to Clipboard and - Save as CSV options would save the time period. In SAM 2016.3.14 the time period is no longer saved. Is it possible to set this as an option?
Angus
Angus
02 Jun 2016 12:40 #4479
Replied by Paul Gilman on topic Slight change to output from Data - Save
Hi Angus,
Thanks for the suggestion. I'm not sure why we changed that in the latest version, but will see if we can reinstate that feature.
If you export the data from the Time Series tab (by right-clicking the graph and choosing an option from the shortcut menu), SAM exports an "Hours since 0:00 Jan 1" column, which is not quite as useful as the time stamp data, but might serve as a workaround for now.
