Feature request: System design - inverter types and their string sizes
- mark.norman
24 May 2016 02:50 #4427
by mark.norman
Feature request: System design - inverter types and their string sizes was created by mark.norman
Can the following be considered for each subarray?
1) different inverters
2) different string lengths
Also can the following be considered
1) Increased number of sub-arrays
2) flexible application of string lengths to multiple input (MPPT) invterters.
Thanks for a great product
Mark
Mark
24 May 2016 15:37 #4428
Replied by Paul Gilman on topic Feature request: System design - inverter types and their string sizes
Hi Mark,
Thank you for this request. We are in the process of making changes to the detailed PV model that will make some of these configurations possible to model in SAM, so the request is timely.
Would you mind describing examples of systems that you would like to model? For example, would you want to model a system with two different brands of inverters, or with two different sizes of the same brand of inverter? What kind of system are you modeling with more than 4 sub-arrays? If have more details but would prefer not to share details on the public forum, please [url=mailto:sam.support@nlr.gov?subject=Inverter%20request t=_self]email me[/url] the descriptions.
- macdonaldtomw
29 Jul 2016 05:58 #4429
by macdonaldtomw
Replied by macdonaldtomw on topic Feature request: System design - inverter types and their string sizes
Hey, wondering when SAM will incorporate multi-MPPT modelling for string inverters that support multiple MPPT channels.
For example, I want to model a system with 8 PV modules facing southeast and 14 PV modules facing west such that the western facing modules are tied to MPPT channel 1 and the southeast facing modules are tied to MPPT channel 2 on a Fronius inverter.
09 Aug 2016 12:30 #4430
We are working on this now, so hopefully it will be part of the next version of SAM to be released around the end of 2016 or beginning of 2017.
- pmanson
08 Sep 2016 11:06 #4431
by pmanson
Replied by pmanson on topic Feature request: System design - inverter types and their string sizes
We also need this feature. We have several PV systems that are not "symmetrical"; for example:
It should be possible to specify the tilt and azimuth at any layer, where the values from the lower layer override the values from the higher layer. For example, you could set the tilt and azimuth for an array, and then override it with different values for a few specific strings (or even modules, although that would probably be a poor design).
- 25 identical 10kW inverters, 1114 identical 265W modules at the same tilt & azimuth, but in a variety of string configurations (1 or 2 MPPTs per inverter, 4 or 5 strings per inverter, 10 or 11 modules per string)
- as above, but with a mix of 245W and 250W modules - some inverters have 4 strings x 11 modules x 245W, some have 4 x 11 x 245 plus 1 x 11 x 250
- 16 identical 24kW inverters, 2 separate roof areas with different tilts and azimuths, 15 to 18 modules per string, some strings of 310W modules and some strings of 315W modules
- 11 inverters ranging from 10kW to 20kW, 3 roof areas with the same tilt but different azimuths, 3 or 5 strings per inverter, all modules identical 315W
- pbrazdil
22 Mar 2018 10:34 #4432
by pbrazdil
Replied by pbrazdil on topic Feature request: System design - inverter types and their string sizes
Any update? Was it released or not? Can't find it anywhere.
