How can I simulate a PV design with not the same number of modules in each string?
- eddy9305
25 Apr 2016 09:21 #4329
by eddy9305
How can I simulate a PV design with not the same number of modules in each string? was created by eddy9305
Is there any way to simulate a PV design with not the same number of modules in each string? The design has 3 subarrays (with 1 inverter per subarray), like this:
*Subarray 1 (2 strings with 11 modules)
*Subarray 2 (2 strings with 11 modules)
*Subarray 3 (1 string with 10 modules)
Something like the uploaded figure.
Thanks.
Regards from México.
Thanks.
25 Apr 2016 12:05 - 18 May 2023 09:32 #4330
Replied by Paul Gilman on topic How can I simulate a PV design with not the same number of modules in each string?
SAM assumes that all modules in the PV array are connected either to a single inverter or to a bank of identical inverters with a single input. For that reason, all subarrays must have the same number of modules per string to maintain a single voltage level.
You could use the "Combine Cases" macro to model your system, or you could model Subarray 3 with 11 modules. To use the macro, you would create a separate case for each subarray, and a fourth case using the generic system model for the financial inputs. See the instructions provided with the macro for details.
Last edit: 18 May 2023 09:32 by Paul Gilman.
- eddy9305
25 Apr 2016 12:20 #4331
by eddy9305
Replied by eddy9305 on topic How can I simulate a PV design with not the same number of modules in each string?
Thank you for your answer. I'll try that macro and see the results.
Regards.
Regards.
10 Aug 2020 09:28 #8538
As of SAM 2018.11.11, the Detailed Photovoltaic model supports inverters with up to four MPPT inputs, which means that you can model a system with up to four subarrays with different string lengths without using the Combine Cases macro. Each string operates at its own voltage, so voltage clipping losses are modeled in a more realistic way than in previous versions of SAM.
