Proxy issue while registrating (error code -1)
- joao.cardoso
29 Mar 2016 12:41 #4219
by joao.cardoso
Proxy issue while registrating (error code -1) was created by joao.cardoso
Dear Sirs,
I'm trying to register the last version of SAM. Unfortunately I run into the following error message: "Registration failed with error code -1. Please check your internet connection."
My company is using a proxy server which I already included in the proxies section. Our proxy requires an authentication (username/password). Could this be the reason of the continuing error messages? How could I indicate the authentication in the proxy.txt file?
Thank you very much for your kind help.
best regards,
João Cardoso
best regards,
João Cardoso
31 Mar 2016 12:25 #4220
Replied by Paul Gilman on topic Proxy issue while registrating (error code -1)
Dear João,
For now, SAM's proxy configuration settings do not support proxy servers that require authentication. We are looking into ways of adding that support, so perhaps that will be possible in a future version of SAM.
In the meantime, I will contact you separately by email to help you get SAM running.
- rashi2410
11 Apr 2016 01:15 #4221
by rashi2410
Replied by rashi2410 on topic Proxy issue while registrating (error code -1)
I am facing the same Issue about the internet connection. The only difference is I am using my home wifi and no proxy server. Please let me know how to solve this issue.
Kind regards,
Rashi
Kind regards,
Rashi
11 Apr 2016 13:17 #4222
Dear Rashi,
I contacted you by email with a solution to your registration problem.
- byron_burns
08 Aug 2016 09:02 #4223
by byron_burns
Replied by byron_burns on topic Proxy issue while registrating (error code -1)
Hello Paul, I have the same issue.
08 Aug 2016 17:37 #4224
Hi Byron,
I will follow up with you by email.
