CSP Linear Fresnel Direct steam
- JinGyu
21 Feb 2016 21:53 #4087
by JinGyu
CSP Linear Fresnel Direct steam was created by JinGyu
The inlet turbine Pressure and Field outlet temperature is changed by flow rate in LFR Direct steam system, I only want to make changing flow rate not but temperature and pressure. Is that possible?
and I want to know full detail of Thermal efficiency and collector optical efficiency.
22 Feb 2016 09:38 #4088
Replied by Paul Gilman on topic CSP Linear Fresnel Direct steam
The model attempts to maintain operation at the design point levels that you specify. For a description of the direct-steam linear Fresnel model in SAM, please see Wagner (2012), listed under "Linear Fresnel" on the Performance Model Documentation page:
sam.nlr.gov/performance
