working fluid in solar water heating system
- hasan123
01 Jan 2016 08:09 #3989
by hasan123
working fluid in solar water heating system was created by hasan123
hello
is it possible to change the fluid that work in the collectors in solar water heating system?
if yes ,how? i want to use a fluid with temperture dependent property.
thank you
thank you
- Zhiyong Tian
04 Jan 2016 05:20 #3990
by Zhiyong Tian
Replied by Zhiyong Tian on topic working fluid in solar water heating system
- hasan123
04 Jan 2016 07:56 #3991
by hasan123
Replied by hasan123 on topic working fluid in solar water heating system
thanks a lot for your answer,
but i can't find my answer in that page and i don't know yet that it is possible to change working fluid property(for example by using scripts).
04 Jan 2016 10:48 #3992
Replied by Paul Gilman on topic working fluid in solar water heating system
SAM's solar water heating model allows you to choose between water and glycol as the working fluid. You make that choice on the Solar Water Heating input page in the System group.
