SRCC data for solar thermal collectors
- Jim Bush
22 Mar 2012 12:11 #400
by Jim Bush
SRCC data for solar thermal collectors was created by Jim Bush
I noticed that there are collectors in the SRCC OG-100 database that are not in the SAM database. I wanted to add one and proceeded to create a custom database and copy in a few to alter based on the SRCC data.
I noticed that the flow rate in SAM does not match the SRCC data. I checked a bunch more collectors and it looks like none of them do. What units for flow rate does the SAM database use? SRCC uses ml/s/m^2.
How often does the SAM databases get updated?
Jim
Jim
11 Apr 2012 14:58 #401
Replied by Paul Gilman on topic SRCC data for solar thermal collectors
Hi Jim,
We're working to try to get an up-to-date solar water heating collector library for SAM from the SRCC database.
As for the test flow rate, it turns out that SAM's solar water heating model does not use the test fluid or test flow rate variables. We have removed them from the user interface to avoid confusion. You can find the correct test conditions and other parameters on the SRCC certificate for each collector.
