PVWatts thermal model intial INOCT value
- nino
27 Sep 2015 04:31 #3746
by nino
PVWatts thermal model intial INOCT value was created by nino
I took a look at PVWatts v5, and in there it says that the initial assumed INOCT temperatures for Fuentes model are:
49°C degrees for close roof mount
45°C for open rack and tracking
I was wondering if you could recommend an INOCT value for mounting configurations with insulated back?
I assume it should be a couple of degrees higher than close roof, but how much?
I understand this question may be difficult to answer, but I would be grateful on an assumption too.
Thank you.
Thank you.
28 Sep 2015 16:09 #3747
Replied by Paul Gilman on topic PVWatts thermal model intial INOCT value
Fuentes (1985) has a discussion about estimating INOCT. Neises (2011) may also be a useful reference.
- nino
30 Sep 2015 08:57 #3748
by nino
Replied by nino on topic PVWatts thermal model intial INOCT value
Thank you Paul.
Great sources, both of them.
- nino
30 Sep 2015 09:11 #3749
by nino
Do you mind if I ask how does PVWatts Fuentes modified model distinguish between different Module types (Standard, Premium, Thin film)?
I took a look at the original Fuentes paper and code you linked above and it only gives an opportunity to distinguish between different mount types by changing the initial INOCT temperature.
But how does PVWatts address the Module type in Fuentes model?
Thank you for the reply.
30 Sep 2015 10:08 #3750
Chapter 3 of the
PVWatts V5 reference manual
explains the difference between the three module types. Table 3 shows that PVWatts V5 uses a different temperature coefficient of power for each module type.
Also, the reference for the Fuentes model that I gave you is different from the one cited in the PVWatts manual: I cited the 1985 Master's thesis, and the manual cites a 1987 Sandia publication .
- nino
30 Sep 2015 12:06 #3751
by nino
Thank you Paul.
In both penultimate and your last reply, the link attached for Funetes model is the one from 1987, released by Sandia:
prod.sandia.gov/techlib/access-control.cgi/1985/850330.pdf
So we are ok.
I checked both the upper 1987 Sandia publication and the fortran code in the Appendixs, and there is no mention of temperature coefficient involved in Fuentes model calculation.
Does that mean that PVWatts does not address the issue of Module type in its modified Fuentes thermal model?
So we are ok.
