Optimization of solar field
- Gabo
08 Sep 2015 13:01 #3686
by Gabo
Optimization of solar field was created by Gabo
Hi, I'm running a simulation of a power tower with molten salts as HTF but when I run de optimization of the solar field it returns higher values everytime. I try changing parameters but it keeps getting higher. what can I do about it?
Gabo.
Gabo.
09 Sep 2015 10:20 #3687
Replied by Paul Gilman on topic Optimization of solar field
Dear Gabo,
I'm not sure what you mean. Could you describe what input parameters you are changing, and exactly what results are different from what you expect?
- Gabo
09 Sep 2015 14:14 #3688
by Gabo
Replied by Gabo on topic Optimization of solar field
I changed Solar multiple, tower heigh, loads hours of TES,heliostat count.
Every time I Optimize, de values like heliostat rows, tower high, receiver dimentions gets bigger even when I try to exaggerate dimentions the optimization makes it bigger.
Gabo.
Gabo.
14 Sep 2015 15:24 #3689
Please see "Using SolarPILOT for Field Optimization" in SAM's Help system, which is in the "Heliostat Field" topic for the molten salt power tower model for a description of how SAM optimizes the solar field for the power tower models. I think that description will help you understand the results you are seeing.
