Can't save utility rates in Windows or OS X with 2015.6.30 version
- schmidly
25 Aug 2015 08:55 #3653
by schmidly
Can't save utility rates in Windows or OS X with 2015.6.30 version was created by schmidly
Hi Paul, I seem to be having problems saving custom-built utility rates in the latest 2015.6.30 release. I tried doing it in both OS X and Windows versions, but I can only 'open' previously saved utility rates and can't save the newly created ones. Can you tell me if this is a user-driven issue or software related? If it's the latter, can you give us a work around or some other feedback? Thanks in advance, Brian
27 Aug 2015 10:59 #3654
Replied by Paul Gilman on topic Can't save utility rates in Windows or OS X with 2015.6.30 version
Dear Brian,
There is a problem that seems only to affect OS X with saving data from the Electricity Rates page to a CSV file. We are working on a solution.
For now, a workaround is to create an empty text file with the extension .csv outside of SAM, and then, in SAM, save the rate to that file.
- schmidly
01 Sep 2015 16:44 #3655
by schmidly
Replied by schmidly on topic Can't save utility rates in Windows or OS X with 2015.6.30 version
Got it. That's helpful. Thanks, Paul..Brian
