steam from turbine
- rabdulqader
20 Aug 2015 05:07 #3640
by rabdulqader
steam from turbine was created by rabdulqader
I’m using SAM for calculating the electrical power output from CSP plant using the physical model. I’m then using the steam from the power turbine for seawater desalination. This means I need to know the amount of steam generated, the temperature and pressure. Does SAM produce this data? If it does where can I find it? If it doesn’t, what information can I use to work out the figures above?
Thank you for your help in anticipation.
Reyad
Reyad
- rabdulqader
20 Aug 2015 05:08 #3641
by rabdulqader
Replied by rabdulqader on topic steam from turbine
20 Aug 2015 10:34 #3642
Replied by Paul Gilman on topic steam from turbine
Dear Reyad,
You can find simulation data on the Results page, either on the Data tab or the Time Series tab.
SAM reports the power cycle HTF temperatures and the condenser pressure. The variable names start with the part of the system they are associated with. For example, all of the power cycle variables start with "Cycle" and the solar field variables start with "Field."
- rabdulqader
24 Oct 2015 03:15 #3643
by rabdulqader
Thank you Paul.
I had a look and found what you mentioned.
Reyad
Reyad
